0 Members and 1 Guest are viewing this topic. Read 2573 times.
Hi to all, ... would 100 watts be enough to drive Magneplanar 1.6Qr ?...
RustyThat is not so hard a question to answer yourself?You know the specs of your maggies, don't youyou know that Maggies are a very very stable load for amps, so 4 ohm is 3.6 or highersensitivit 85, 86 db per watt.So add 3 db for 2 watts2 watts 89 db4 watts 92 db8 watts 95 db16 watt 98 db32 watt 101 db 64 watt 104 db so 55 watt will be around 102 to 103 db (very loud!!)and 100 watts will give you close to 106 db.This is not for peakpeak values of the AKSA's is 3db (I su ...
