VPI Scout 1.1 vs 2?
0 Members and 1 Guest are viewing this topic. Read 3646 times.
Rivalaudio
VPI Scout 1.1 vs 2?
« on: 6 Aug 2014, 09:26 pm »
I understand the only difference in these 2 is the platter, any input on whether or not its worth the jump in price?
AudioSoul
Re: VPI Scout 1.1 vs 2?
« Reply #1 on: 7 Aug 2014, 06:12 pm »
  There is no 2 the 1.1 is the second edition with the classic platter. From reports I've read the 1.1 has better definition in all areas than the original with plastic platter......
Rivalaudio
« Reply #2 on: 7 Aug 2014, 06:41 pm »
You sure about that?
http://vpiindustries.com/table-scout11.htm
VPI - The Scout 1.1 and 2 Turntable
Celebrating over 10 years in Production! We bring you it's re-birth!
brooklyn
« Reply #3 on: 7 Aug 2014, 08:17 pm »
Hi Rivalaudio, I have the original VPI Scout with the acrylic platter which I’ve owned for about 8 years now. There is no doubt for me, (at my age) this will be my last turntable, I like it that much.
That said, I am not familiar with the new models but if I had to pick between one, I would go with the heavier platter (if it’s within your budget) especially if you think you will be keeping it for a long time.
When it comes to turntables, the more mass the better. Take your time and buy once.
Below is a picture of mine.
Brooklyn
Gzerro
« Reply #4 on: 7 Aug 2014, 11:08 pm »
Once you get to the Scout 2 price ($2,500) you may want to consider moving up to the VPI Classic ($3,000). It is a much more massive table and also comes with a better arm. Seems more bang for the buck imo.
Good luck!
Tom
AudioSoul
« Reply #5 on: 10 Aug 2014, 10:25 pm »
Brooklyn
Ok sorry about that!
