SOLD SOLD SOLD
0 Members and 1 Guest are viewing this topic. Read 932 times.
doak
SOLD SOLD SOLD
« on: 4 Aug 2014, 10:14 pm »
Passive preamplifier based on Tortuga Audio LDR3x board with HiZ option. It uses pairs of microchip controlled Silonex LDR’s to achieve the best in signal attenuation with perfect balance.
Preamp has 3 inputs and 1 pair of outputs -  also has 12V trigger output.
All functions are controlled by remote as well as front panel rotary encoder: Power On/Off, Volume, Balance, Mute, Input Select. Unit can also be controlled via Apple Remote.   Remote works beautifully and is a joy to use.
This preamp sounds absolutely incredible in that it has little/no sound of its own - amazing transparency with perfect balance.
Listing includes the preamp, remote, PLUS 2 amp, 3-12 volt variable regulated linear power supply (yes, it makes a difference).
Price:  $450 DELIVERED in cont. US!
« Last Edit: 6 Aug 2014, 09:34 pm by doak »
sfox7076
Can you post pics to the power supply or a link?  Thanks.
Brettio
Re: SOLD SOLD SOLD
« Reply #2 on: 8 Aug 2014, 07:04 pm »
doak,
Congratulations on the sale of your preamp and thank you for marking it 'sold' while leaving the entire ad up.  I believe this not only follows the sites posting guidelines but allows others to reference your ad for information, pricing, etc.  I wish the others that delete their ad (or worse, just marking 'sold' in the subject line and body and erasing everything else) after it sells would extend the same courtesy.
Brett
srb
Yes, but it would be even better to leave the subject title intact and merely change the FS: prefix to SOLD: prefix
SOLD: Tortuga LDR3x Passive Preamplifier : Professionally Built
