BRYSTON SYSTEM REVIEW
0 Members and 1 Guest are viewing this topic. Read 1139 times.
  • The Demo is Everything!
    • http://www.bryston.com
So There
  • Brystonized
Re: BRYSTON SYSTEM REVIEW
« Reply #1 on: 31 Jul 2014, 09:22 pm »
Congratulations, James. I experience the same outstanding performance with my Bryston gear. I can't wait to hear your Mr. T speakers (Didn't he say, "I pity the fool who doesn't have Bryston"?)
Rich
________________
Whiney Napa Valley
The means — Bryston SP3 | Bryston 6B-SST(C) - L/C/R; 4B-SST(C) - surrounds; 4B-SST(C) - rears | Bryston BDP-2 Digital Player; BDA-2 D/A Converter; Oppo BDP-105 | Paradigm Reference Signature S8 fronts; C5 center; ADP surrounds; S4 rears; two Velodyne DD15 subs | APC S20 | Pioneer Elite PRO-1130
martydmnt
« Reply #2 on: 5 Aug 2014, 08:16 pm »
I'm a little confused where this special version of B135 with balanced connectors came from,
"I hooked the system up using the balanced audio connectors (why doesn't everyone use these yet) this system allows you to go from source (BDP-2) to amplifier (B135-SST2) using balanced connectors."
Otherwise, I think it's great to see a system review consisting of (almost) all the same brand working together. If only he had a pair of Mini T's, too.
« Reply #3 on: 7 Aug 2014, 10:15 am »
HI
He was thinking of the BP17 Preamp ( preamp section in the B135) when he mentions the Balanced circuit - it is Balanced out though not Balanced in.
james
