Cartridge(s) for Bryston BP1.5 Phono Stage
0 Members and 1 Guest are viewing this topic. Read 1215 times.
Samurai7595
« on: 23 Jul 2014, 01:38 pm »
I'm considering getting a Bryston BP1.5 phono stage for my analog setup.
For BP1.5 owners, what cartridge(s) are you using with your BP-1.5?
Are you pleased with the performance of the BP1.5 and is it a dead-quiet phono stage?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Cartridge(s) for Bryston BP1.5 Phono Stage
« Reply #1 on: 23 Jul 2014, 02:25 pm »
I have used a number of Ortofon cartridges both MM and MC with good success.
james
WBimmer
« Reply #2 on: 24 Jul 2014, 03:45 pm »
I'm using a Clearaudio Talismann V2 Gold and it sounds wonderful with my Bryston gear.
Wayne.
alexone
« Reply #3 on: 24 Jul 2014, 09:04 pm »
hi, Samurai!
i'm using Ortofon Rondo Red MC. if you prefer a bit more bass and a slightly "darker" sound then try this one.
i like it :D
al.
Hicham
« Reply #4 on: 27 Jul 2014, 11:02 pm »
Hi Samurai
I use Ortophon 2m Black . This is an MM CARTRIDGE. The BP 1.5  provides details that surprise me for I was not aware of , Solid Bass, and thrilling rhythm. I intened to also get an Ortphon Rondo MC. I consider my BP 1.5 as my best component period.
turnovertherecord
  • rain,fog,snow,sun,known to happen on the same day
« Reply #5 on: 28 Jul 2014, 01:58 pm »
I am using a CA MC on a concept TT
Pre is a bp-25 mc
