Rogue Audio Stealth Magnum Phono Preamp MM/MC PRICE REDUCTION!
0 Members and 1 Guest are viewing this topic. Read 3761 times.
Travis
I am the second owner of this very nice phono stage preamp. The Stealth has had the Magnum upgrades and also sports the AD797 op-amps. The Stealth is in very good cosmetic condition with a small mark on the top edge of the faceplate, very hard to see. In fact, you have to feel it so you can see it. I will be moving to an all tube phono preamp. I have the original inner carton for the unit, but not the outer. The unit will be double boxed and over packed to insure safe transit.
A few specs:
Moving magnet (mm) or Moving coil (mc) operation - High performance op amp circuit topology - Precise RIAA equalization - Massive fully regulated power supply - Toroidal transformer - Internal settings for 100, 300, 1000 and 47k Ohm loading - Internal setting for 150 Picofared or 0 capacitance loading - Four gain settings: 46dB, 50dB, 60dB, 65dB - Ultra heavy-duty gold RCA inputs - Precision components throughout - Heavy machined aluminum faceplate - Two heavy (2 ounce) copper circuit boards - Teflon/silver plated hook-up wire - Detachable IEC power cord (included) - Entirely designed and built in the USA
I can email more close up pics of the interior upon request.
MSRP:  $1095  Asking:  $600 REDUCED!
Paypal only
Buyer is responsible for USPS shipping charges, approximaely $30 to lower 48
Flawless feedback on Audiogon and AudioAsylum - Travis
« Last Edit: 20 Aug 2014, 03:32 pm by Travis »
