0 Members and 1 Guest are viewing this topic. Read 10025 times.
I was able to play music on and off but JR kept freezing. If you hit skip, pause, even stop, then tried to hit play it just froze up. Restart JR and then it starts giving errors about your poor choice of resolution choices or whatever. Now I cannot get any music to play. I have tried toggling everything I can find and nuttin.
Since I got the Chord I have had very little music flowing. I thought the Ipad interface was causing a communications confusion with the MS-2. but when I run the music purely from the JR software with a mouse it still freezes. I do not see where changing from FLAC to DSD is causing this but heck if I know again.
Just got back from picking out the paint color for my new speakers.Chord recommends the Kernel Bitstreaming set-up. The "best" running stretch I have had is with:Audio device: kernel streaming driver versus the asynch driver (downloaded from the Chord CD),Device settings at 24 bitDSP to upsampling the 44, 48, 88 to 192 and the rest unchanged Channels to 2 chanel stereo no mixingNo other boxes checked except for Output formattingBitstreaming to DSDPrebuffering to 6 seconds2 second silencetwo boxes left unchecked: memory and disable display
Just got back from picking out the paint color for my new speakers.Chord recommends the Kernel Bitstreaming set-up. After that I am kinda lost on what is right or wrong. I've had music playing after it took 4 days to analyze the audio.I did watch the two Ted videos and even made a DSD Audio "folder" and even pushed that up to the Ipad per Ted's instructions. Before I sold the Lampizator I occasionally had freezing and I thought it was the dac. What do I know.Since I got the Chord I have had very little music flowing. I thought the Ipad interface was causing a communications confusion with the MS-2. but when I run the music purely from the JR software with a mouse it still freezes. I do not see where changing from FLAC to DSD is causing this but heck if I know again.The "best" running stretch I have had is with:Audio device: kernel streaming driver versus the asynch driver (downloaded from the Chord CD),Device settings at 24 bitDSP to upsampling the 44, 48, 88 to 192 and the rest unchanged Channels to 2 chanel stereo no mixingNo other boxes checked except for Output formattingBitstreaming to DSDPrebuffering to 6 seconds2 second silencetwo boxes left unchecked: memory and disable displayAnd now with a DSF file I have played before the Playback Problem says could not be started on the output Kernel Streaming using the DoP 5.6MHz 2ch.Not sure why this is. ALso have the very latest JR downloaded last night: 19.0.154
Tried JPLay on the MS2 to no avail.Downloaded JR to my laptop and the same failures occur, so the driver for the dac is foobared. It freezes right up if you hit pause or stop.
