Subwoofer conection options.
0 Members and 1 Guest are viewing this topic. Read 958 times.
Merckx1
« on: 17 Jul 2014, 06:57 pm »
I have a pretty nice, sealed, 10" Parts Express subwoofer with a blown plate amp.
Could I pull out my unused 2-channel power amp to power it? I'd connect the power amp like I used to connect the sub Using RCA's from the second set of outputs on my preamp and run some zip cord to the speaker binding posts on the sub.
If I did that would the subs' crossover still work?
Best,
Mike
Bob in St. Louis
Re: Subwoofer conection options.
« Reply #1 on: 23 Jul 2014, 02:49 pm »
Hey Mike,
The driver won't care where the power is coming from, so yea...the "donor" amp will work. Not sure about running it through the plate amp, I doubt it. You can take the amp off and make a wood cover plate with a hole to accept the new wires, or, drill a hole in the box and run new wires through it leaving the dead amp as the cover plate.
I've fixed some 'dead' amps by replacing the bad caps in them. Do a Google search for your model number with key words like 'dead', 'blown', etc.....
You might be able to fix the amp for less than $5-$10.
Bob
