what is a Supertweeters?
0 Members and 1 Guest are viewing this topic. Read 1332 times.
orientalexpress
« on: 17 Jul 2014, 05:20 pm »
Why do speakers needed?It is possible to DIY one?TIA
Danny Richie
Re: what is a Supertweeters?
« Reply #1 on: 17 Jul 2014, 09:58 pm »
For a super tweeter to work it needs to cover a range from 20kHz and up. This can add spacial cues that help open up the sound stage and imaging. And it is not hard to DIY one. You can accomplish a similar effect from an up firing or rear firing tweeter.
However, the majority of the time they are improperly implemented by allowing them to play down into lower ranges also covered by another tweeter or another driver. This will cause cancellation effects and holes in the response. So don't always look at them as being a positive.
Hugh
    • Angel City Audio
« Reply #2 on: 17 Jul 2014, 10:24 pm »
What he said. :)
This is why we didn't use it in our Trinity when we designed it using Onix Reference drivers.
orientalexpress
« Reply #3 on: 18 Jul 2014, 05:55 pm »
sweet,which tweeters do u recommend to use as superttweeter?Thanks again
