7B SST different volumes
0 Members and 1 Guest are viewing this topic. Read 935 times.
RonCH
« on: 17 Jul 2014, 12:34 pm »
Hi,
In the past year I've had both of my 7B SSTs in for repair, and now they have different volumes ( gains ).  I swapped the amps around, so I'm sure that it's not a cabling or preamp problem.  As a workaround I'm running one amp at 1V gain and the other at 2V and now they are both producing roughly the same volume.  Hardly an ideal solution though.  I guess I have to send my amps back in.  Right?
  • The Demo is Everything!
    • http://www.bryston.com
Re: 7B SST different volumes
« Reply #1 on: 17 Jul 2014, 01:01 pm »
Hi,
That sounds really strange Ron.  The loudest setting would be the 1Volt setting.  Email Mike and see what he thinks.  [email protected]
james
RonCH
« Reply #2 on: 17 Jul 2014, 01:16 pm »
james
Thanks for the quick reply.  With both amps 1V is the loudest.
Using a iPhone app and a Left-Right volume test signal I get:
1V  Right  80.1dB
      Left    85.2dB
2V  Right  73.9dB
      Left    79.0dB
I'll email Mike.  Thanks.
Ron
RonCH
« Reply #3 on: 17 Jul 2014, 01:17 pm »
And they still sound great.   :)
