3B SST won't Turn On?
0 Members and 1 Guest are viewing this topic. Read 1857 times.
Mag
« on: 16 Jul 2014, 01:19 am »
I can't get my 3B SST to power up. Was using it for my center channel, but wasn't using center channel for awhile so I turned it off, front switch. Now I want to use the amp again and it won't power up. I want it to turn on when I turn the power conditioner on, but can't get it to power up any way.
Any ideas on what I could be doing wrong? :?
  • The Demo is Everything!
    • http://www.bryston.com
Re: 3B SST won't Turn On?
« Reply #1 on: 16 Jul 2014, 02:12 am »
Hi Mag
Unplug it from the wall or power conditioner - then make sure the circuit breaker on the back of the amp is in the ON position - then plug it back into the power - then turn on front switch
james
Mag
« Reply #2 on: 16 Jul 2014, 02:29 am »
No go. I wonder maybe I wrecked something when I inserted the wrong power cord instead of the slotted one? I checked the fuse and it looks good to me.
Still using the 3B ST for my 100's but wanted the extra power of the SST.
« Reply #3 on: 16 Jul 2014, 02:31 am »
Email Mike Pickett tomorrow and he may be able to help.
[email protected]
james
Rod_S
« Reply #4 on: 16 Jul 2014, 11:34 am »
Do you have a trigger hooked up? If so make sure your settings haven't accidently been switched from remote to manual. Even if you do use a trigger it might not be a bad idea to switch it over to manual and try turning it on that way, just to give both ways a try. I use remote power triggers and when the power goes out from a storm when the gear is in use the amps don't come back on on their own when I power everything up again. I always have to press the front power switches to get them to fire up that initial time.
« Reply #5 on: 16 Jul 2014, 12:45 pm »
Good input Rod - thanks.
james
Rod_S
« Reply #6 on: 16 Jul 2014, 05:46 pm »
No prob, always willing to assist when I can  :thumb:
