Sold: Martin Logan Theatre Center Channel Speaker
0 Members and 1 Guest are viewing this topic. Read 1217 times.
sfig
« on: 16 Jul 2014, 12:41 am »
Martin Logan Theatre Center Channel Speaker in excellent condition for $sold plus shipping.  Includes speaker, mounting bracket/stand, power cable and original box.  Lots of great reviews of this available.  Buyer pays 3% for paypal if used.  Local pick up in Los Angeles area welcome.
Frequency Response
70–22,000 Hz ±3dB
Horizontal Dispersion
30°
High Frequency Transducer
Three 1" (2.54) soft dome, controlled dispersion array
Mid Frequency Transducer
Patented CLS™ electrostatic transducer
Low Frequency Transducer
Two 6.5" (16.5cm) magnetically shielded. Non-resonance asymmetrical chamber format.
Sensitivity
90 dB/2.83 volts/meter
Impedance
Nominal: 4 Ohms
Minimum: 3.1 Ohms at 140 Hz. Compatible with 4, 6, or 8 Ohm rated amplifiers.
Recommended Amplifier Power
20‒500 watts per channel
Crossover Frequency
300, 3000 Hz
Components
Custom wound audio transformer, air core coils, polypropylene capacitors
Inputs
Custom 5-way binding posts
Weight
57 lbs. (26 kg)
Dimensions (without wall-mount/stand)
10.5" × 43" × 11.5"
(26.7cm × 109.2cm × 29.2cm)
Dimensions (with wall-mount/stand)
13" × 43" × 11.5"
(33cm × 109.2cm × 29.2cm)
« Last Edit: 21 Jul 2014, 03:04 am by sfig »
