Smoother cable
0 Members and 1 Guest are viewing this topic. Read 2602 times.
mca
Smoother cable
« on: 29 Aug 2004, 04:18 pm »
My new Gallo Reference 3's present so much more detail and high frequency information than any other speaker I have owned. For the most part they sound great, but I think they are exposing some weakness in my inexpensive AP Oval One interconnects and Oval 12 speaker cables. Can someone give me some ideas on new cables to try that will help me enjoy all this new detail. I don't want to spend a mint, just want something that is a good step up from the AP's.
marvda1
  • freelance reviewer: The Sound Advocate
new cables
« Reply #1 on: 29 Aug 2004, 04:23 pm »
go to  www.ecoustics.com  and under cables do a search for zu julians or zu oxyfuel.
zybar
Re: Smoother cable
« Reply #2 on: 29 Aug 2004, 04:53 pm »
Quote from: mca
How much do you want to spend?
How long a length do you need?
George
mca
Smoother cable
« Reply #3 on: 30 Aug 2004, 05:00 am »
I need 1 pair of 1m interconnects and 8' speaker wires. I plan to buy used and would like to spend around $750 max.
zybar
Smoother cable
« Reply #4 on: 30 Aug 2004, 12:54 pm »
Quote from: mca
IC's are easy - VH Audio Pulsars.  Will set you back less than $100 and there is a 60 day return period.  Don't let the price fool you.  Chris' xlr version replaced ic's in my system that retail over $1200/2M and his digital ic replaced a $500/1M ic.
Speaker cable is more difficult, but with all the money you are saving on the ic's you really have tons of options with the remianing $650.
George
  • Speakers....What Speakers ?
Smoother cable
« Reply #5 on: 30 Aug 2004, 02:03 pm »
Quote from: zybar
Quote from: mca
George
Pulsars are a good choice, but I think they would run around $150.00 now for a 1M pair. You can check.....here...
Marbles
Smoother cable
« Reply #6 on: 30 Aug 2004, 02:24 pm »
Bolder Nitro is very good for the speaker cable, Ridge Street Audio Poeima! is very good too.
zybar
Smoother cable
« Reply #7 on: 30 Aug 2004, 02:29 pm »
Thanks for the correction Chris.
Rob, there isn't a way to stay within his budget and get those, is there?
George
Smoother cable
« Reply #8 on: 30 Aug 2004, 02:33 pm »
Quote from: zybar
George
Marbles...any used cable at you place...Bolder or RSA ?? :o
Marbles
Smoother cable
« Reply #9 on: 30 Aug 2004, 02:50 pm »
George, only in the used market.
Wolfy, no, unfortuneatly I am sending to Wayne my 16' Nitro cable in exchange for a pair of Summit IC's.
As it happens Robert had a 4' used pair of Poeima speaker cables that he brought down with him on Saturday for my office system.  Sounds so good I just paypaled him for them.
mca
Smoother cable
« Reply #10 on: 30 Aug 2004, 06:29 pm »
Anyone know why VH Audio does not make a speaker cable? I have heard good things about the interconnects, but would kind of like to stay with the same brand for both. It's just a synergy belief that I have.
I did find a review of the Zu cables on PF online. They liked them, but the problem with that is, they seem to like and gush over any cable they review!
vpolineni
Smoother cable
« Reply #11 on: 30 Aug 2004, 06:42 pm »
Chris Venhaus told me that he is working on some speaker cables that he plans on releasing this fall/winter.  He puts a lot of research into his products-he spent more than a year designing the pulsar.  FWIW, I am a satisfied customer with his flavor 4 power cord and a balanced pulsar cable.
zybar
Smoother cable
« Reply #12 on: 30 Aug 2004, 06:52 pm »
Quote from: mca
As Vasu stated below, it is on Chris's roadmap.  YOu can contact Chris for more info.  I am sure he can work with you on achieving your single vendor goal.
Conatct him ASAP since he goes on vacation soon.
George
