***SOLD*** Epos Elan 15 speakers w/ ST15 stands (Excellent match with Creek)
0 Members and 1 Guest are viewing this topic. Read 2945 times.
Sense63
***SOLD***
First owner Epos Elan 15 speakers (including ST15 stands) for sale in excellent condition.  If you're not familiar with Epos, they are a British designed speaker and sound very similar to Harbeth, but at a fraction of the price.  Fit and finish are excellent and do some things better than the Harbeth Compact 7 IMO.  I've owned the Compact 7's, and they are wonderful speakers, but can be a bit laid back and warm sounding.  The Elan 15 has no listening fatigue, has that magical midrange, but is not as laid back and more "live" sounding.  They are an excellent match with Creek electronics, but work well with anything over 20wpc.) These are a steal at my asking price.
Speakers- $1400 retail; ST15 stands- $300 retail
Power Handling: 120 Watts unclipped speech and music
Frequency Range: 47 Hz – 25 kHz
Impedance: 4 Ohm nominal
Sensitivity: 90dB / 2.83V@1m
Amplifier Compatibility: 20 – 120 Watts
Tweeter: Epos 25mm soft dome with high-temperature voice coil, ferrofluid cooling and neodymium magnet system. Magnetically shielded
Bass/Midrange Drivers: Epos 187mm dia., with cast chassis, 25mm high-temperature voice coil and polypropylene cone. Magnetically shielded.
Crossover Frequencies: 3.2kHz
Crossover: Bass and tweeter networks both use 2nd order filters. Metal oxide resistors and polypropylene film capacitors. The tweeter section has an air-cored inductor, and the woofer section features a large-core laminated-iron inductor.
Terminal Panel: Bi-wirable. Can be single or double wired by removing shorting links provided.
Ideal Positioning: Not less than 4" from rear wall
Internal wiring: Solid-core Audiophile grade copper cable
Cabinet: 18mm MDF wrap and front baffle, extensively braced internally
Finish: Cherry or Black Oak real-wood veneer
Grilles: Removable ‘audiophile’ grille fitted as standard, Alternative cloth-covered grilles are packed as accessories.
Dimensions (HWD): 16.4" x 8.3" x 11"
Weight: 19.4 lbs. per speaker, 46.2 lbs. per carton
Shipping paid by buyer. If you're in the Chicago area, of course pickup would be welcome.
« Last Edit: 20 Aug 2014, 05:38 pm by Sense63 »
