0 Members and 1 Guest are viewing this topic. Read 9470 times.
So err ... now that a few months have passed can you share what the other speaker was?
Are you still in this room, and have you needed to add any treatment to it?I sit in front of a window like the one in your picture, with just blinds and no curtains. Only my window is 12 feet wide. So I'm seriously considering if I should add some sort of heavy curtains over the window to damp echoes.
My guess is that the speakers were the KEF LS50. Only one speaker I know of fits that description given the cost and rave around the globe. However, to be fair, if it was the LS50, that speaker can sound REALLY crummy when driven with inadequate power/current capability amps and not brought out to the room to breath. It should, however, have lower bass extension than the 3i. Just one person's guess....a bit of fun. UL
Finally heard the LS50 at the Axpona KEF room (end of the day) and was very let down after all the media attention (maybe they're equipment matching/setup fussy). The tiny $600 Napa system (tube pre/solid state power integrated with small 2-ways) we heard next was much more natural/musical in another large room (obviously not best of show, but extremely impressive and the highlight of the day).
I lived with the KEF LS50's for over a year, and they are very good speakers, BUT there are always caveats. I wish reviewers made more effort to explain their listening environment, seating position, and nominal SPLs.What I found:1. They sound thin at low volumes (not uncommon of many/most speakers).
I lived with the KEF LS50's for over a year, and they are very good speakers, BUT there are always caveats. I wish reviewers made more effort to explain their listening environment, seating position, and nominal SPLs.What I found:1. They sound thin at low volumes (not uncommon of many/most speakers). This is problematic for me as I tend to listen at "comfortable" levels the majority of the
The lower the efficiency, the more likely a speaker will sound thin at low volumes. The higher the efficiency, the more likely a speaker will sound fleshed out at low volumes. However the opposite is also true. Low efficiency speakers sound more alive and fleshed out than high efficiency speakers at higher sound pressure levels.I'm certain that if you still had the Kef LS50, you find them superior to the Omegas at higher sound pressure levels.
This setup was before I had my listening room ready. I put the system down in my listening room and then it sold not long after that. I hadn't treated the room in the picture, but strange to say it worked really well - sort of concert hall rather than intimate listening. The green area rug went down into my listening room and I haven't replaced it upstairs, but if I do, I may set something up there again.
Have you posted a picture of your listening room? I'm interested to know how to set one up properly.
I've heard this before and yet also heard speaker designers disagree with this assessment. I'm not challenging your assertions but simply want to understand: 1. Why is this, if it is so? 2. What is the mechanical basis for this?
Well, how do headphones work then? I'm pretty sure good speakers of any size are fine at low volume.
