Printing Power Points?
0 Members and 1 Guest are viewing this topic. Read 1023 times.
Speedskater
  • Kevin
« on: 8 Jul 2014, 05:13 pm »
Are there any easy tricks to printing out Power Points to eliminate the blue background?  It's a great waste of blue ink.
TF1216
Re: Printing Power Points?
« Reply #1 on: 8 Jul 2014, 06:04 pm »
I am proponent of changing the presentation slide size to 16:9.  Be aware, if the slide size is changed after material has been added that material will be stretched.
I don't think the 16:9 format will help you but I am willing to help.  Might you be able to send your presentation over to look at?  My e-mail address is tyler.folsom at gmail.
Big Red Machine
« Reply #2 on: 8 Jul 2014, 06:26 pm »
Do you mean the background color of each slide?  That is easily changed.
randytsuch
« Reply #3 on: 8 Jul 2014, 08:23 pm »
You may need to change the slide master to change the background color.
Doublej
« Reply #4 on: 8 Jul 2014, 10:29 pm »
Try printing in pure black and white. That might do it for you.
Speedskater
  • Kevin
« Reply #5 on: 9 Jul 2014, 12:29 am »
I'll try the black & white idea.  They are other writer's presentations, not mine.
