A370PEQ Enclosure
0 Members and 1 Guest are viewing this topic. Read 1195 times.
A370PEQ Enclosure
« on: 7 Jul 2014, 04:14 am »
Ok,  I found the cutout dimensions  (11.125 x 9.125)   but I am wondering how much  depth I need.  Aso,  do I need a lot of  "breathing room"   or can the  dimensions (LxW) of the enclosure  just be  large enough to   support the   amp ?
-jay
« Last Edit: 7 Jul 2014, 06:43 am by Captainhemo »
jparkhur
Re: A370PEQ Enclosure
« Reply #1 on: 7 Jul 2014, 03:03 pm »
I alwYs left two inches between the floor and amp back. That may be more than you need but have never had and amp overheat either.  I had one guy who wanted a shallower box so I only left one once between back of amp and open floor.  I never put a bottom on any of my amp boxes but also don't have littles running around.
Jon
Danny Richie
« Reply #2 on: 7 Jul 2014, 03:15 pm »
The four sided boxes I use with them are 5" thick.
ebag4
« Reply #3 on: 7 Jul 2014, 03:20 pm »
Mine are 4 5/8" deep, I believe I built them using 1/2" material for the back, so a 5 sided box.  No issues to date.
Best,
Ed
« Reply #4 on: 7 Jul 2014, 03:41 pm »
Thanks guys , much appreciated
-jay
