Bi amp able speakers.
0 Members and 1 Guest are viewing this topic. Read 1085 times.
ricardojoa
« on: 1 Jul 2014, 05:24 pm »
Hi guys, got a question about bi amp capable speakers.
Assuming a pair of speakers capable of bi amp, does that mean when the jumpers are disconnected, the high/mid and low will get seperated? For example, if the jumpers are disconnected and only the top bindinpost is connect, then only the mid and highs will play. Is that correct?
And if you only connect the bottom bindinpost, then only bass will play.
I never own biamp capable speakers, and that what i thought how they are designed.
Please fill me in.
Thx
AJinFLA
  • Soundfield Audio Loudspeakers
    • Soundfield Audio
Re: Bi amp able speakers.
« Reply #1 on: 1 Jul 2014, 06:06 pm »
Yes, you have it right.
cheers,
AJ
