Survey: What supports do you use with Bryston?
0 Members and 1 Guest are viewing this topic. Read 2776 times.
AlexB
« on: 28 Aug 2004, 01:29 pm »
What supports/platforms/spikes/feet etc. do you use with Bryston pre- or power-  to a good effect?
JarrettH
« Reply #1 on: 29 Aug 2004, 04:06 pm »
Little rubber feet out of this material you can chop with scissors, lol.
I only have a B60 and Arcam CD72T...no rack for me yet. :lol:
JarrettH
« Reply #2 on: 29 Aug 2004, 04:08 pm »
I think Bryston owners are the most sane audiophiles out there. :D  :mrgreen:
KJ
« Reply #3 on: 29 Aug 2004, 04:56 pm »
Stock Bryston rubber pads (3B-ST) sitting on a shelf of a Contours audio rack.
-KJ
Eric
« Reply #4 on: 29 Aug 2004, 05:04 pm »
None under amp, Symposium Svelte Shelf and rollerballs / blocks under BP-20 preamp
Ron D
« Reply #5 on: 30 Aug 2004, 01:51 am »
80 lb amp sits directly on the bottom shelf of my Skylan stand.
ec
« Reply #6 on: 30 Aug 2004, 05:28 am »
The SP 1.7 sits on the very top of a home made plywood shelf / equipment rack.  The 3B SST sits on top of a Panamax power distribution unit.  In a few months this will change when one of my friends makes a furniture grade audio cabinet for me.
The 4B SST and 6B SST sit on Target amp stands under my screen.  I use these amp stands so no one will hoof the amps accidentally.
totally agree.  Not sure if I consider myself sane posting @ 1:30 in the morning when I have be up in about 5 hours.
Fife
« Reply #7 on: 30 Aug 2004, 07:36 am »
I got a Sound Anchor stand stand and I am going to do some home-made mods.
Allezvite
Supports for Bryston
« Reply #8 on: 30 Aug 2004, 02:04 pm »
My Bryston 3BSST sits at the bottom of a typical solid pine audio cabinet.  I know, not ideal, but it seems to work fine.  I'm sure an audiophile-approved support stand would be better, but I'm surprised that the sound is as good as it is with this typical family-room type of stereo furniture.
I had cut-outs put in the back for connections and airflow.  The 3BSST gets just slightly warm and never really gets hot.
gravy
  • -Scott
« Reply #9 on: 30 Aug 2004, 07:50 pm »
Using 48" high rack mount rails in a recessed wall cabinet with access to back.  4 Screws hold the sp17, 4B & 6B SST to the rails.
I'm also using angle irons to support underneath the 4B SST & 6B SST.
Rock solid.
Fife12
« Reply #10 on: 5 Oct 2004, 08:14 pm »
Here's mine.
