(4) 3 FT Cullen Crossover Series Power Cable
0 Members and 1 Guest are viewing this topic. Read 498 times.
loving_it
« on: 29 Jun 2014, 06:52 pm »
This Power cable brings to the table the perfect blend of Silver and Copper.It is completely hand built from the ground up. I start with 3 – 12 Awg 99.99% Pure Silver Plated Copper with Teflon Dielectric. I braid the 3 wires in a way to virtually eliminate any Noise present. Then the wires are shielded with a 100% coverage Tinned Copper Shield Braid. This makes for a drop dead Silent Power Cable. After that the shielded wires are wrapped with a Teflon Wrap and then for a great cosmetic look covered with Black Techflex Sleeving.
The Perfect blend of Silver and Copper makes for a very tube like sound. But Not Bright or Dull. You will find yourself playing a track over and over again because you hear sounds that were not previously identifiable. Available in 15 amp or 20 amp Terminations. (20 Amp IEC connectors is a Hubbell 320HC)
Power Cable Features:
Military Spec Wire
12 Awg 99.99% Pure Silver Plated Wires (Line, Neutral, and Ground)
Teflon Dielectric which provides an extremely Quick and accurate Power Cable
Available with a 15 Amp or 20 Amp IEC
100% Shield Braid Coverage
Super Flexible
Completely Hand built from the Ground up
Made in The USA!
Connectors:
18k Platinum plating over 99.99% OFC Solid Red Copper On both IEC and Plug
Cryo Treated for 48 Hours at -192 degrees
150.00 EACH all (4) 550.00  I will cover Pay Pal also
