A/V-1RS Question
0 Members and 1 Guest are viewing this topic. Read 1514 times.
Ron
A/V-1RS Question
« on: 29 Jun 2014, 06:19 pm »
  Are the A/V-1RS rear sound speakers also compatible with the X-LS Encores or just with the GR Research A/V series speakers?
« Last Edit: 30 Jun 2014, 10:25 am by Ron »
mlundy57
Re: A/V-1RS Question
« Reply #1 on: 30 Jun 2014, 01:06 pm »
In the past Danny has said the AV-1RS works well as surrounds with his speakers. Lye has said that with surrounds, the woofers are more important than the tweeters.
I wonder how this will work with Dolby Atmos where they say it is important that the surrounds be as good and timber matched to the mains. With this new format surround channels will no longer be limited to restricted ambient signals.
jazyes
« Reply #2 on: 30 Jun 2014, 01:07 pm »
Hi Ron,
Now that I have my L/R/C set-up, I was wondering the same. -John
Danny Richie
« Reply #3 on: 30 Jun 2014, 04:04 pm »
Yep, they will match with them perfectly.
Ron
« Reply #4 on: 30 Jun 2014, 05:35 pm »
  Thanks !  I sort of figured they would work well with the X-LS Encores, but really wasn't sure. Appreciate the answer to my question.
