0 Members and 1 Guest are viewing this topic. Read 2670 times.
I just cleaned my table off for a sale, and found it difficult to get everything completely clean without using a sponge and dish soap (not too many suds), and then wiping with a rubbing alcohol soaked paper towel. This seemed to work on the metal and MDF parts, as well as the golf ball.
Lighter fluid is what I use. Works well and quickly.Steve
I recall that the manual said lighter fluid, but Mike P also said rubbing alcohol. I guess there are options!Oscar, I think the WTL tables are great, and happy to get someone started down the vinyl road. He's a student that has discovered 1000s of records in his university library to enjoy. Here in SF, the library LPs are so worn and scratched I wouldn't even think about it.
it is hard to clean,i will suggest use towel paper first,and after use alcohol
