Cheap option to add headphones to TV...
0 Members and 1 Guest are viewing this topic. Read 1065 times.
« on: 29 Jun 2014, 04:43 am »
What's a cheap option to add a headphone amplifier and headphones to a modern LCD TV that does not have a headphone jack?
Mind you, this is for an older person and they are not going to be buying anything costing multi-hundred dollars.
Doublej
Re: Cheap option to add headphones to TV...
« Reply #1 on: 29 Jun 2014, 10:19 am »
What type of outputs does the TV have? Are they fixed level or variable level? Do you want a remote control or not? I think you are going to need a small amplifier or receiver.
If space is not an issue this HK might solve your problem. $120.
http://www.harmanaudio.com/search_browse/product_detail.asp?urlMaterialNumber=AVR%201565-Z&CJPID=CJ
If the TV has variable RCA output you might be able to use a $3 female 3.5mm to male RCA plug converter but I don't know if there will be any impedance mismatch issues.
There are also specialized wireless headsets for this purpose. Here's a link:
http://www.head-fi.org/t/647514/top5-best-wireless-headphones-for-the-tv-buying-guide
« Reply #2 on: 30 Jun 2014, 05:23 am »
Isn't there a cheap headphone amp? They are not going to use a receiver.
Doublej
« Reply #3 on: 11 Jul 2014, 11:34 pm »
Sure. Look at the Topping T21, MUSE AT-HA20, Schiit Magni or FiiO. Do a search for headphone amplifiers on Parts Express and you'll see a number of choices. I have no idea how any of them sound.
Often they come with a DAC but that shouldn't bother you.
I am guessing that the folks at head-fi.org can help too!
