Minimum sidewall placement for SS8
0 Members and 1 Guest are viewing this topic. Read 914 times.
kmcdonou4eq5
« on: 27 Jun 2014, 01:14 am »
I just picked up a used pair of SS8s in great condition. How close to the sidewalls can they be placed and still sound good?  They are going in a corner of a larger room, but the corner is only 11' wide.  I have a wall mounted TV that I can slide a little one way or another, but my speaker placement is limited.
I sent an email to Jim, but while I am awaiting his response, I thought I would ask others.
Big Red Machine
Re: Minimum sidewall placement for SS8
« Reply #1 on: 27 Jun 2014, 01:34 am »
18" and I put diffusors right at those reflection points since they were so close and I wanted to spread that reflection out as best I could.
Austin08
« Reply #2 on: 27 Jun 2014, 02:32 am »
I suggest starting with 8 feet tweeter to tweeter (with tweeter to the inside and slightly toe-in) and put bass traps or diffusers next to it on side walls.
