SOLD VAC Phi Beta 110i integrated amplifier from the Valve Amplification Company
0 Members and 1 Guest are viewing this topic. Read 3166 times.
achappy
Original shipping boxes, remote and manual.
Asking Price:  SOLD
New Price: $22,000.00
For sale is one of the finest tube integrated amplifiers.  The bass through this amplifier is simply outstanding, musical and powerful - the best I have ever heard from any amplifier, solid-state included.  It will ship directly from VAC where it just passed presale inspection.  This 110i operates at spec.
FREE SHIPPING AND INSURANCE if you buy this 110i before Monday, 30 June 2014, 6 pm EST.
There are two original shipping boxes.  Their measurements and weights are at the very end of the Description below.
Buyer pays for shipping and insurance.  If using PayPal, please add 3%.
Thanks for looking.
The following is from the VAC site:
Description:
The VAC Phi Beta integrated amplifier is, quite simply, the finest audio amplification solution available, bar none. By combining the heritage of the Phi separate components with the inherent possible advantages of the integrated embodiment, an entirely new level of performance has been attained. With the VAC Phi Beta you hear all of the "hi-fi" attributes, but in a way totally subservient to the feel and emotion of the music. After all, that is what music is all about.
The single greatest advantage of the integrated form is the fact that all of the amplification stages, both pre- and power, can refer to a single, tight ground reference. This provides a reference point for the signal that is unsurpassed. In essence, it is the strongest, most elegant foundation possible. Properly implemented, as in the Phi Beta, the resulting sonic purity, dynamics, and detail are absolutely astounding.
The one major drawback to integrated amplifiers of the past has been due to radiated noise fields from the power supply. To overcome this, the Phi Beta utilizes a massive external power supply that may be located as much as six feet from the audio chassis. Of course, final power reservoirs and ground references are located in the audio chassis.
The integrated design allows complete control of the interface between the two components. This eliminates one set of interconnect cables and spares the audio signal from another trip through the outside world, which sidesteps an opportunity for RFI and EMI pickup.
Internally, the Phi Beta incorporates the superb MM/MC phono stage of the Phi 2.0 Master Control amplifier, an all-new line stage with balanced inputs and outputs, and a potent power amplifier derived from the Phi 110/110 power amplifier.
Remote control of power, input selector, tape monitor, cinema input, mute, and volume. All controls are duplicated on the front panel with simple, direct acting switches. All line inputs may be assigned as volume-controllable, or as fixed-gain inputs for sources with their own level controls. Can communicate with other Phi components via the iVAC data buss 12 volt triggers, allow control of other brands of ancillary equipment. With preamplifier outputs (balanced and RCA) and switchable power amplifier direct inputs, it is easy to use external crossovers and/or biamplify with the Phi Beta.
Intensity of illuminated VAC logo varies with ambient room light level. Audio chassis is machined from aircraft aluminum. Output tubes continuously monitored by VAC Beam Power Sentry circuit, which alerts you when a tube should be replaced and shuts the amplifier off if a KT88 fails. 110 watt/channel output into 2, 4, or 8 ohm speakers, double choke power filtering, complete regulation of all heater and 'housekeeping' circuits and typical 8,000 hour average tube life.
The most important feature, of course, is the sound quality. It is the result of VAC's relentless attention to detail and thousands of hours of "voicing". Once heard, it will redefine your expectation of what is possible and, thereafter, necessary.
Approximate dimensions:
Audio chassis: 17.7" x 17" x 9.2" (W x D x H) plus knobs and connectors; shipping box: 22" x 25" x 13", shipping weight: 100 lbs.
Power supply: 9.2" x 14.5" x 9" (W x D x H); shipping box: 13" x 18" x 13", shipping weight: 42 lbs.
Shipper is FedEx.  Shipping only to USA addresses.
« Last Edit: 4 Jul 2014, 07:47 pm by achappy »
rpf
Gorgeous amp. Ah, if I were only rich.
Good luck with the sale.
achappy
Thanks, rpf.  I appreciate the feedback.
