Adding Large Power Supply Capacitors
0 Members and 1 Guest are viewing this topic. Read 1346 times.
Speedskater
  • Kevin
« on: 23 Jun 2014, 06:58 pm »
I just saw this Walt Jung note on another forum about why adding huge power supply capacitors can be a bad idea.
Energy Storage Bank
Yes, Tony did ask me about posting that article, which covers a lot of things discussed here. I thank him for the courtesy of requesting permission to post the article, which was: "Build An Energy Storage Bank, Walter G. Jung, Audio, August 1980". While it would certainly fit into the context of this DIYAudio thread, I really can't recommend it any longer, and so I have declined the request to make it unconditionally available. As noted within, it isn't a beginner project.
Among the reasons for this is the fact that there are subtle downsides to using such a filter bank, which many might not fully appreciate. The (very) high current pulses in the caps generate RFI, which can be a problem, even when the system is carefully constructed and all of the appropriate soft-start issues are fully addressed. As a DIY add on project, this point is particularly cogent, since the caps must be outside-the-box. Also, the added wiring, connectors, etc. will tend to negate part of the effectiveness of the ultra-low Z of the bank as seen right at the terminals. By contrast, look at the Bear Labs internally mounted, buss-bar strapped filter caps: http://bearlabsusa.com/NEXT/SYMPHPS.jpg
Having said all this, I don't wish to be seen as preventing information to be shared. If anyone is in dire need of my Audio article, simply email me, via DIYAudio or my website contact page.
__________________
Walt Jung
Website blog: www.waltsblog.waltjung.org
Folsom
Re: Adding Large Power Supply Capacitors
« Reply #1 on: 4 Jul 2014, 05:53 am »
How big is he talking? That looks like it's in reference to adding hundreds of thousands of uf... as the amplifier in the picture probably can suck 10+ amps.
Most of the DIY around here are talking less than 50kuf most of the time (and internal).
I'm not sure who this is in reference to, given the utter extremeness of the picture given. It's pretty rare even on DIYaudio I see more than a 35w class A amplifier. (as a somewhat casual reader/poster)
G Georgopoulos
« Reply #2 on: 4 Jul 2014, 06:19 am »
oh yeah,if you are building big class-a amplifiers you have no other option..??.. :green:
