m 4b sst 2 just poped..
0 Members and 1 Guest are viewing this topic. Read 1472 times.
krbabu
« on: 23 Jun 2014, 10:16 am »
hi i was listening to songs and  i paused for a while  when i heard a pop sound not so loud.
what could have gone wrong?
now no lights and  totally dead..  planning to take it to my dealer in singapore - local set 4 months old.
can any body share your experience
babu
  • The Demo is Everything!
    • http://www.bryston.com
Re: m 4b sst 2 just poped..
« Reply #1 on: 23 Jun 2014, 10:51 am »
babu
Hi babu
Could be a fuse.
james
krbabu
« Reply #2 on: 23 Jun 2014, 11:25 am »
thanks James , can i change it myself  or should i go to the Agent.?
« Reply #3 on: 23 Jun 2014, 12:00 pm »
Email Mike Pickett at Bryston and ask his advice - [email protected]
james
turnovertherecord
  • rain,fog,snow,sun,known to happen on the same day
« Reply #4 on: 23 Jun 2014, 07:52 pm »
[email protected]
This is the email to his office,he will respond within 1 hour or so,he is very good at responding
krbabu
« Reply #5 on: 24 Jun 2014, 11:58 am »
Thanks a lot i will email him to the second email you had given.
Just a question ,  when you switch on  the amp do you get a click sound only or  a click sound followed by a few clicks  and then the led inside turns green .
because i  had this sound like this for a while , might be something is wrong.  I did not have the time to go today so i am thinking of going to the dealer tomorrow.
Thanks a lot in advance.
regards
babu
« Reply #6 on: 24 Jun 2014, 12:38 pm »
regards
babu
Hi babu
The click sound is normal.
james
krbabu
« Reply #7 on: 25 Jun 2014, 01:28 pm »
Thanks James
I went to the local dealer , But he told me that there are no   Fuse in the new 4B SST2    model  ???!!!  .  Any body can advise.
I hope that there are no other issues .
Still awaiting the reply from Mike @ bryston.ca.
hopefully everything is resolved.
chers
sfraser
« Reply #8 on: 25 Jun 2014, 01:53 pm »
Could it possibly be your circuit fuse (fuse box)?
