Are there any passive preamps with a remote?
0 Members and 1 Guest are viewing this topic. Read 2192 times.
Hantra
« on: 18 Feb 2003, 08:21 am »
All:
I have been looking at the McIntosh 6500 and 6900.  I love the sound of those pieces, and I love integrated amps, but I also like having a remote!  Should I get a passive with a remote, and a MC202?
B
JohnR
« Reply #1 on: 18 Feb 2003, 08:40 am »
Bent has just announced a remote control option. Not sure if that's of interest..
ABEX
« Reply #2 on: 18 Feb 2003, 09:56 am »
I thought some Placette's have a remote.
If you want to save some $$ get an FT Audio LW-1 which will be coming out with a remote add-on real soon.
Write to Paul Lam and ask him about it.
 http://www.ftaudio.com/
If you are thinking you really need a remote all I can tell you is I thought I would really need one also,but after getting the unit I found I could just Mute\Pause my CDP if I needed to it off.
Happy Hunting!
BlackCat
« Reply #3 on: 18 Feb 2003, 07:02 pm »
If you want to save a lot of $$, check out the Creek OBH-12.  Highly rated, and you can find them for as little as $200 U.S.  It's frequently referred to as a "remote volume control", but it does have remote source selection also.  I think they are only around $300 brand new.
ABEX
« Reply #4 on: 19 Feb 2003, 07:43 pm »
How could I forget the Creek's.Although the FT Audio's have better input capability and will be adding a remote for alittle more.
I got lucky and found a used model.
Also FT's cirsuit allows for greater flexibility when mating with an amp I think.
Just a thought.
doug s.
  • makin' music
« Reply #5 on: 19 Feb 2003, 08:56 pm »
when i was using an electrocompaniet ec-1a pre, & wanted remote-control, audio advisor lost a sale, by recommending against the obh-12 - they said i would *not* like the reduced transparency...
but, creek makes a full-function remote-control passive pre - the 43r - that's supposed to be good, tho i have no 1st-hand knowledge...
http://www.musichallaudio.com/products/products.asp?lookup=p43
doug s.
ABEX
« Reply #6 on: 19 Feb 2003, 09:18 pm »
How much is the cost of the unit if you know?
TIA
doug s.
  • makin' music
« Reply #7 on: 19 Feb 2003, 09:40 pm »
well, a call to musichall would certainly give up-to-date cost info, but if i recall, i tink it lists for  $600...
hth,
doug s.
