Which sub for Adam Audio Artist5 monitors?
0 Members and 1 Guest are viewing this topic. Read 1871 times.
guido
« on: 14 Jun 2014, 12:35 pm »
I am looking at a sub for my Adam Artist 5 monitors.
I am looking at the Adam Sub7 [or Artist sub7] which I assume are identical except maybe the finish.
Would I be better off with the Sub8 and its lower bass extension?
How would be the best way to connect this sub?
Should I connect the monitors to the outputs on the sub thus bypassing the low frequencies to the monitors completely or is there a better way?
Any other subs to consider?
Letitroll98
  • Too loud is just right
Re: Which sub for Adam Audio Artist5 monitors?
« Reply #1 on: 14 Jun 2014, 03:27 pm »
Well it kinda depends on what you want the sub for.  The Artist Sub is more of a low bass driver than a true sub, which in my way of thinking is fine for music as 32Hz encompasses just about all of the relevant musical spectrum, others may disagree.  If you use them for HT, then they may fall a bit short of reproducing all of the special effects encoded on bombastic releases.  The other problem is one you mentioned, hookup.  As you have active speakers, having a sub designed to integrate well with the XLR or RCA connections is a big plus.  I'm sure there are other subs that are designed to integrate with active speakers, but my first thought would be the company brand.
« Reply #2 on: 14 Jun 2014, 06:01 pm »
Sub selection should be based on listening distance/room size as well.  A bigger/lower F3 sub will overpower a smaller space (speaking from experience).   Too much of a good thing is not a good thing (in this case can cause resonances at higher frequencies, loss of lease/domestic tranquility, even structural cracks).  Also keep in mind that professional subs are more conservatively rated and that with very few exceptions music stops at 30 Hz anyway, so professional subs for music typically are rated down to 30 Hz and ~ 20 Hz for game/movie uses.  In a really small space (desktop in an alcove/closet) this speaker, with F3 of 50 Hz, wouldn't want a sub.  But in a say 2,000 - 2,500 cubic foot room (and the Adam speakers can do a surprisingly good job of filling a room) a sub would be useful.  But by then it'd be best to have a "swam" of subs available (search AC or read Floyd E Toole's "Sound Reproduction" that explains how bass behaves in a room).
How you connect depends too on if you want to run the Artist 5's full range (possibly better blending with sub), or use a low frequency cut off filter (typically in the range of 80 - 120 Hz) to relieve the Artist 5's of "heavy lifting" of lower bass which can help "open up" midrange performance.  As the Artist 5 is an active speaker with DAC (built-in amps) you can only input low level analog signals or digital.  Possible ways to connect your speakers:
 - Low level output from a sub (most subwoofers have this feature, again consider if you want to pass through the full or filtered signal (or best of both worlds have the option for either)
 - Low level output from a pre-amp (some pre-amps have separate subwoofer outputs, my upscale pre-amp even has variable filters)
Note that some worry about purity of signal going through a sub to get to your main speakers (IMO only a theoretical issue if cabling/sub are decent quality).
Please let us know what you come up with.
« Last Edit: 22 Jun 2014, 10:48 am by JLM »
