0 Members and 1 Guest are viewing this topic. Read 3825 times.
There was a lot of talk, many years ago, concerning upgrading the RM-40 with a FST tweeter. Brian even sold a 'Kit' for the upgrade. Though, that didn't work out too well, as the Kit never included a new tweeter faceplate, as planned. Be that as it may, I was able to find a few threads that might help:http://www.audiocircle.com/index.php?topic=678.0http://www.audiocircle.com/index.php?topic=3170.0http://www.audiocircle.com/index.php?topic=60430.0Also, as noted, Brax has been at this a while. So, the spiral tweeters must still be very good, and work as designed! Oh yea, it's also a shame that the RM-40 Series 2 never happened as planned. I bet they would have been sweet!Especially, since they would have used a side-mounted 12" passive radiator, in place of the bottom mounted 10" passive. Now, given the choice, and the skills, I'd try that even before upgrading the tweeter. I guess I'm a bass-headafter all...! Good Luck!
It's anti-intuitive, and looks less good, but there's one simple correct philosophy for locating PRs on stereo loudspeakers: PR location and firing direction must be as non-symmetrical as possible between L and R speakers. For instance: On the L speaker locate PR on the R side panel (all views from the listening side), as close to the base as possible. On the R speaker locate PR on the R panel as close to the ceiling as possible, or alternate for R speaker locate PR on the top panel firing up toward the ceiling.
Also, frankly, Brian's driver radiating ratios (PR vs. active driver) are generally lacking in PR area. IMO approximately doubling PR radiating area in most cases is a very reasonable goal. The worst case, which Brian eventually dropped at my urging too, was the original RM30 with active 10, which had way too small cabinet and woefully too little PR area (mine bottomed the PRs almost daily they were so badly over-driven....this model's Q was way too high from the too small enclosure).
I presume a 15PR has about 50% more radiating surface area vs. a 10" active woofer.
Thanks for the info Brax and Stempy. Brax, will the G3's you have run off the spiral tweet leads? I understand the AC tweets have a transformer. Did I read you had changed to the lambs wool behind the panels? Was this a worth while upgrade. Im sure this has been answered in the past. Is the opening left by the spirals deep enough to fit a G series tweeter?
Pierre Sprey of Mapleshade records/recording helped design control systems for the F16 and/or F18. About 15-20 years ago my friend Mike Mindlin told me that Peirre told him that symmetrical woofer siting is always wrong, and that woofers should be as non-symmetrical L to R as possible. I certainly had absolutely no idea what Pierre was up to at the time, but now have hands on experience confirming his philosophy. I mixed together multiple bass source information of LeJeune, Tod Welti, and Earl Geddes with Bob Carver's siting instructions for a single sub, into very simple and efficient instructions for siting a distributed sub array for minimum bass mode effects.
Adding additional subs, creates a "multiple different" interaction patterns and a summed perception at the listening position, and begins a "smoothing" of the specific interaction of a single or fewer subs. This also explains why irregular placement of even stereo subs will often offer advantages. However, if a room is irregularly shaped and each of a stereo pair "sees" a different set of room boundaries from their specific position (that is you are not in a perfectly rectangular or square room) then that balanced positioning can be quite effective.
