0 Members and 1 Guest are viewing this topic. Read 9255 times.
Would also like to be able to plug power amps into it, something I didn't think was a good idea with the Hydra.
I would especially not plug a tube amp into one.
Why can't you plug a power amp into a power strip (conditioner) that will pass 15 amps? Fifteen amps? Why not? What makes a tube amp so special that you have to plug it directly into the wall?
I'm glad you are an audiophile, and not a medical doctor.
to be confident in your choices, if you purchased a $29 Kil-o-watt device, you could mneasre all your device current draws and then size something accordingly.
I think no Furman is the answer.
The PI products, Audience, and my own tend to be the ones I recommend. But there's a lot of effective stuff, how some of it sounds is up to you.
