Onix SP3 tube amp/$450 plus shipping / SOLD!!
0 Members and 1 Guest are viewing this topic. Read 1134 times.
rockn
« on: 8 Jun 2014, 04:50 pm »
For sale Onix SP3 tube amp engineered in Australia. Amp sounds great but has a few nicks from previous owner. All new tubes with less than 100hrs on them plus the original tubes. Amp is heavy at 65lbs so shipping could be costly from Michigan,48026. local pickup would be nice but i will ship. Plenty of great reviews on line. Thanks Bob
« Last Edit: 10 Jun 2014, 12:59 pm by rockn »
flavo
Re: Onix SP3 tube amp/$450 plus shipping
« Reply #1 on: 9 Jun 2014, 12:39 pm »
Hi
Are the tubes in it now the same as the factory tubes, or has something new been rolled in? What is that front panel made of? Why are you getting rid of it? How much heat does this put off? I have a smaller tube pre and that's my only experience with tubes so far.
Thanks, MIke
rockn
« Reply #2 on: 9 Jun 2014, 01:01 pm »
There are no tubes in it now that I have packed it. You have your choice of the original or the new ones. The newer tubes are the ones in the box. The front panel is made of some kind of metal, the tubes put off some heat but the unit itself  doesn't get hot. I'm selling because I have class D mono amps now which work better with my speakers.
