question on cabinet volume
0 Members and 1 Guest are viewing this topic. Read 1154 times.
ricardojoa
« on: 7 Jun 2014, 07:26 am »
So assume i modeled the woofer with a 30 liter requirements, does that mean i need to buil the box slightly larger to accomodate drives displacement and bracing? I guess yes, but just need a little confirmation.
Muser
  • I post at audiogon as muser, and write for PFO.
    • Positive-Feedback Online
Re: question on cabinet volume
« Reply #1 on: 7 Jun 2014, 08:07 am »
Your answer is here : http://www.hometheatershack.com/forums/enclosure-volume-calculator/
Drivers and ports "shrink" the volume.
Hope the link helps you.
« Reply #2 on: 7 Jun 2014, 11:04 am »
Many pro audio raw speakers brands inform the vol displaced by its drivers.
Usually the vol box recommended by an manufacturer for its project/drivers are the gross vol.
« Last Edit: 7 Jun 2014, 12:22 pm by FULLRANGEMAN »
