audioengr wrote:
Sorry, Kevin, but I have to differ with you on the synergy thing. In my experience unless you are using cables as tone controls, there is no synergy, only good sounding and bad sounding cables.
audioengr, your statement suggests that cables should not be used as tone controls, which implies that cables will only 'color' the way one's components sound. I see a big problem with this viewpoint because it seems to be based on the premise that the rest of one's system has a completely neutral sound.
There is no such thing as a neutral sounding component; let alone a neutral sounding system. Different cables have different tonal qualities, just like any other component. Achieving system synergy is based on one's personal tastes and expectations, and the way a cable interacts will vary depending on the other components it is paired with.
there is...only good sounding and bad sounding cables.
I can agree with this to a degree. It is possible to have a cable that sounds good in just about any system if it is designed well, but that doesn't mean it will sound
best in every system. With any given system there may be one cable that excels over another, but just the reverse may be true when inserted in a different system.
I very recently auditioned a cable that faired very badly in my system vs. my current cable. When I changed out one component, my P-3A dac for the built-in dac in my cd player, the cable sounded positively wonderful. My own cable sounded good both ways, supporting your theory, but it sounded better with the P-3A. When comparing both cables when using the cd player only, the audition cable came out ahead of my cable.
I believe this makes a very strong case for synergy.
Dan, I like your frankness, but burn-in does take many hours. I think this could be easily demonstrated in blind tests.
