Rectifier Tubes
0 Members and 1 Guest are viewing this topic. Read 2811 times.
kleinbje
Rectifier Tubes
« on: 6 Jun 2014, 06:00 am »
I have been rolling some 6X4's in my phono pre.  One single FW rectifier tube.   It came with an amperex from the 70's, I rolled in a GE from '52 NOS, everything just seemed better.   The amperex had detail, but it was like being at a museum, no groove, didn't rock.  The Ge's were spacious, just huge soundstage, slightly more noise than the amperexs, but damn quiet.  Being shocked at the difference a rectifier tube( afuckindiode!) had on the sound, I ordered a bunch more tubes, the ge was bought just to have a backup in house.  I picked up a sylvania in a yellow box, cant find the date code, I rolled that in last week.  Wow!!  The difference was startling.  The vocals are much more present and "thick", the bass is way deeper, and this is not hyperbole , I am talking resonances where there never were any at the same volume level.  The sound stage is a bit smaller, but still big, it seems to be quieter than the GE.  It really rocks though, it just presents music with more of that x-factor that keeps you engaged.  I have 2 RCA's and another 2 GE's to try, it is really startling the difference in sound between these tubes.  It seems when I changed 6922/7308's in my Chinook the differences were much more subtle, though I was comparing very high grade tubes and my system is much more revealing with the Lamm.  Looking for advice and recommendations
Re: Rectifier Tubes
« Reply #1 on: 7 Jun 2014, 03:48 am »
The fewer sections of filtering, the more difference the rectifier tube and power transformer will have on the "sound".
Cheers.
« Last Edit: 7 Jun 2014, 01:33 pm by Steve »
Re: Rectifier Tubes
« Reply #2 on: 9 Jun 2014, 11:47 am »
Hi Steve,
Is the Russian 5C8S a better rectifier than the western versions??
It do 1700V.
http://www.mif.pg.gda.pl/homepages/frank/sheets/084/5/5C8S.pdf
Re: Rectifier Tubes
« Reply #3 on: 9 Jun 2014, 05:13 pm »
Hi Steve,
It do 1700V.
If it is used in MIGs, it probably is more sturdy. Can't read Russian, but if one can, is the G rating on the data sheet. From a sound issue, no idea.
Cheers
Re: Rectifier Tubes
« Reply #4 on: 10 Jun 2014, 02:50 am »
Fwiw its used in the Lampizator GM70 amp, but not in the Lamp 211 amp which use the 5C3S.
