Audio/Video Gear and Systems
The Acoustics Circle
Rob Babcock
Cloud Mounting Acoustic Panels
0 Members and 1 Guest are viewing this topic. Read 1626 times.
SetterP
Dual-Channel Zealot
5 Jun 2014, 11:11 pm »
I recently made some DIY acoustic panels, and was wondering if anybody has suggestions for mounting them on the ceiling (i.e, cloud mounting).
Any bracket, wire, fastening recommendations would be appreciated.
WireNut
ยป
Re: Cloud Mounting Acoustic Panels
5 Jun 2014, 11:18 pm »
You may have seen these whisperwave clouds before. If not here's the link. I think they look pretty cool.
There is an instruction video on how they are installed.
http://www.acousticalsolutions.com/594~whisperwave-clouds
Glenn Kuras
Industry Participant
Reply #2 on:
6 Jun 2014, 01:34 pm »
I would put eye hooks in the back of your panel (4) and use loose weight change to attach to the back and the ceiling. You can count the links to make sure it is totally flat. For the ceiling us a hook that is rated for hanging plants.
Glenn Kuras
GIK Acoustics
Rob Babcock
