A/V-1RS with X-LS Encore components, Will it work?
0 Members and 1 Guest are viewing this topic. Read 1100 times.
batman7349
I have X-LS Encore for my front stage with a X-CS Encore for a center channel. Now it's time to upgrade my surrounds from LX5's to a pair A/V-1RS. What would be the results of using the Encore components instead of of the A/V-1's?
Danny Richie
Re: A/V-1RS with X-LS Encore components, Will it work?
« Reply #1 on: 4 Jun 2014, 02:30 am »
A/V-1's, the A/V-1RS, and the X-Series Encore speakers are all very different. The parts do not interchange.  Only the designed crossover will work properly with each speaker. Mixing them will make a mess of the response.
batman7349
« Reply #2 on: 5 Jun 2014, 10:48 pm »
Thanks Danny, I'll just put away a few more bucks and order the proper kit! :thumb:
Danny Richie
« Reply #3 on: 5 Jun 2014, 11:15 pm »
And another good thing about all of those kits is that none of them are very expensive.
