FS: GR Super V -$3000 DC Pickup
0 Members and 1 Guest are viewing this topic. Read 796 times.
dragoonxp20
« on: 3 Jun 2014, 12:04 am »
I have the yellow pair in this post
http://www.audiocircle.com/index.php?topic=100658.msg1015656#msg1015656
I need to sell these before the end of June. I originally bought the pair for $5500 + shipping. I am going to be going to OTS for the air force next month and will be moving quite a bit afterwards. It's just not feasible for me to keep moving them.
It has the upgraded Jupiter caps and I built some simple enclosures for the amps that have a chassis neutrik speakon connector.
There are some slight nicks that were present when I received them. One of the spikes ripped out and was gorilla glued back in so it is the only one that isn't removable. Missing a couple pieces of no-res that you can easily replace or I can if purchased early enough. Overall they are in a 7/10 condition conservatively, but look perfect with the grills on.
I would like $3000 for the speakers and the amps picked up from Sterling, VA. I may be able to deliver within a reasonable distance for the cost of gas.
« Last Edit: 3 Jun 2014, 09:26 pm by dragoonxp20 »
