X-LS Encore v LGK's
0 Members and 1 Guest are viewing this topic. Read 3585 times.
NeilT
X-LS Encore v LGK's
« on: 1 Jun 2014, 01:20 am »
I am in the process of building an office system and,
Looking for a comparison of these 2 speakers.
Danny please chime in on this one.
I built a set of the Encores, for my brother, and really enjoyed their sound.
I realize, off the bat, that the LGK's will need supplemental bass.
Neil
« Last Edit: 1 Jun 2014, 02:51 pm by NeilT »
mlundy57
Re: X-LS Encore v LGK's
« Reply #1 on: 1 Jun 2014, 02:44 am »
Neil,
I have both X-LS Encores (with upgraded crossovers) and LGK's. I have listened to each pair of speakers, both in a desktop (near field) setup in my office and as main speakers in a small (11' x 13') room with the main listening position 10' from the speakers. Listening included with and without a subwoofer in each situation.
In the office desktop system I prefer the LGK's. As mains with a 10' listening distance I prefer the Encores. I prefer subs with both the Encores and the LGK's however, the bass extension and output of the LGK's in a near field situation is surprisingly good by themselves.
Mike
cody69
« Reply #2 on: 1 Jun 2014, 12:43 pm »
I agree with Mike... for up close listening the LGKs are great, and although they have the ability to be used as mains in a small room setting, I prefer the X-LS for this application... they seem to fill the room better.
Both are excellent choices and very easy to drive. Let us know which once you choose.
Danny Richie
« Reply #3 on: 2 Jun 2014, 04:39 pm »
Those guys pretty well nailed it.
For a mid sized room and standard listening distance the X-LS speakers are overall better for that application. But in a near field application you may really like the LGK's better.
X-LS's will play loud without issues while the LGK's are SPL limited.
BK_856er
« Reply #4 on: 2 Jun 2014, 04:56 pm »
I recently built both the X-LS Encore and the LGK and I would agree completely.
Really enjoying my LGK for near field, desktop use (and small room).
I'm getting along just fine without supplemental bass, but I like to have projects in the queue.  What's a good subwoofer to build?  In my case it would need to go under a large desk due to space constraints.
BK
« Reply #5 on: 2 Jun 2014, 05:28 pm »
An 8" servo sub  only needs a .7 cu ft  sealed enclsure  :thumb:
-jay
NeilT
« Reply #6 on: 2 Jun 2014, 10:24 pm »
Thanks guys.
Jay, do you know if anybody has built a, single driver, sealed, 8 inch, servo sub yet?
or more details on that.
Neil
« Reply #7 on: 3 Jun 2014, 04:32 am »
eHey Neil
I don't  know if anyone has built one yet,  thought maybe BK wanted to be the first  :lol:
Seriously, there is the 4 ohm version being offered on the Rythmik site so  I'd imagine in a samll room  paired with the LGK's,  it should work very well
Danny or Brian  (or anyone else for that matter) have  you guys tried a single 8" in a small room  ?
A couple more ?'s about the 8' drivers...
I assume 3 of the 16FR model in parallel can be run off one  HX300 amp ?
How would  3 of them compare  to  a pair of  12's ?
I am  still  kicking aorund ideas of what I am  going to pair with my OB7's but I am probably only going to be able to start with a single H frame and add a 2nd later.
-jay
Danny Richie
« Reply #8 on: 3 Jun 2014, 02:39 pm »
I haven't tried one in a small room. My room is big. And Brian has the lower Q versions. I just have the 16FR versions here.
Yes.
A little tighter and more controlled, but won't play as low or as loud down low.
mlundy57
« Reply #9 on: 3 Jun 2014, 03:42 pm »
Will the 12's handle the 200Hz crossover point of the MMTMM?  I notice the A370PEQ amp's crossover only goes up to 120Hz while the HX300's crossover goes up to 200Hz.
NeilT
« Reply #10 on: 3 Jun 2014, 04:41 pm »
Danny, what would you recommend for a 8" single sealed version?
Driver ??
Amp ??
Can you and would there be any advantage / disadvantage to a ported version?
Neil
Danny Richie
« Reply #11 on: 3 Jun 2014, 05:03 pm »
The 12's in an open baffle easily reach that level. In the Super-V and Super-7 designs the dial on the crossover has to be set in the 80 to 100Hz region for them to crossover (-6db down) in the 180 to 200Hz range.
Danny Richie
« Reply #12 on: 3 Jun 2014, 05:05 pm »
Driver ??
Amp ??
Neil
Hey Neil,
Brian's DS800-3: http://www.rythmikaudio.com/DS800drivers.html
And the HX300 amp: http://www.rythmikaudio.com/compact_amplifiers.html
No advantage in porting it.
