New interconnect cable from tweakaudio
0 Members and 1 Guest are viewing this topic. Read 6838 times.
Ric Schultz
« on: 29 May 2014, 08:11 pm »
The EVS-1 interconnect is now available.  $250 per meter pair unbalanced.  Using the incredible Neotech braided litz PCOCC wires.....lots of them.  30 day money back guarantee.  I have been playing with wires since the late 70s.  This wire is the first wire I have ever been excited about.  Very seriously transparent with no glare.  Very revealing but if you use enough of it.....then totally full bodied as well.  Please see:  http://www.tweakaudio.com/EVS-2/EVS_Interconnects.html    for more info and a large pic.
« Last Edit: 30 May 2014, 05:04 am by Ric Schultz »
Ron D
Re: New interconnect cable from tweakaudio
« Reply #1 on: 30 May 2014, 05:01 am »
While I am sure that your design has been optimized for the best end result could you not leave the plug housing in place to reduce the opportunity for damage for those people who tend to swap cables on a frequent basis?
Ric Schultz
« Reply #2 on: 30 May 2014, 05:24 am »
The combination of the new heavier metaled connections on the KLE Innovations RCA jacks and all the heavy wire from the doubled up Neotech 20 gauge wires (17 gauge total) makes the connection points very strong and resilient to damage.  The 24 gauge wire for damping is spiraled around at the end adding more mass and solidity...and adding the Teflon tape and heatshrink make it more so.  The wires cannot short on one another (notice the thick plastic barrier between the hot and ground and remember all the wires are litz (coated).  No problem plugging and unplugging these many times.
I can make them with the plastic housing but they will not sound as good.  Same price.
« Last Edit: 30 May 2014, 06:26 pm by Ric Schultz »
Early B.
« Reply #3 on: 31 May 2014, 12:40 am »
This seems to be a very interesting design. I'd love to read some customer reviews here on AC once folks buy these and try them out.
Phil A
« Reply #4 on: 31 May 2014, 05:12 pm »
Looks very interesting.  In process of getting the main system together after a move after the rack gets together and the components get put on it might be something to consider
Ric Schultz
« Reply #5 on: 13 Jun 2014, 07:57 am »
Just received the following email from one of the first EVS-1 cable users:
Hi Ric. I just wanted to thank you about how magical your EVS Interconnect cable is. When I got it 3 days ago, my initial hope and excitement actually turned into somewhat of a worry at first. I was using Crimson cable IC cable which has worked very well for me previously. Although your IC cable sounded slightly better, I was not sure it was really worth changing. I began to hate the fact that I'm an audiophile, always hoping to improve my system but not achieving that goal at all no matter what I do. I have Wilson Sophia speakers and LFD NCSE integrated amp and Sony HAP Z1ES as a music server/player. Being an audiophile has been a silently frustrating journey because I never really liked my system that much although it's not exactly a cheap set up. Sure, it sounded just fine but never amazing. However, when I listened to my audio one day later using the EVS IC cable, the unthinkable happened. Literally. I could not believe that I had the same system except your new IC cable. The music now has so much more clarity and pureness with outstanding dynamics and musicality. All my CDs sounded amazing, even the ones I did not think much of before. It was an absolute, instantaneous transformation. I am now grateful that I am an audiophile. It is an absolute aural thrill to listen to all my music. I now love my speakers, my integrated amp and the music player. I just cannot believe your IC cable could make that much difference. By the way, you are absolutely correct about the directionality of the IC cable. I thought it was sort of a voodoo idea but it is true nonetheless. One direction sounds more correct and sounded much better than the opposite direction. I do not understand the rationale for this but I can hear the difference. Your damping material for EVS IC cable is also wonderful since your IC cable truly comes alive with the damping material. I so eagerly wait for you to mod my Sony HAP Z1ES to the next level of audio experience, the "rapture with music".
marc5656
« Reply #6 on: 24 Jun 2014, 06:32 am »
HI
Were did you get that cable from and what is the cost for two four foot cables?
Marc
marc5656
« Reply #7 on: 24 Jun 2014, 06:34 am »
I found it
mamba315
« Reply #8 on: 11 Aug 2014, 07:40 pm »
Is the XLR version done?
