Using 2 USB Sticks with my BDP-2
0 Members and 1 Guest are viewing this topic. Read 666 times.
Samurai7595
« on: 28 May 2014, 06:53 pm »
I currently have a USB stick connected to one of the front USB ports on my BDP-2 player and the main folder is called Music.
If I connect a second USB stick to the other front USB port of my BDP-2 player, can it be the same make/model and size as my existing USB stick and can the main folder also be called Music?
If not, how do I handle this?
If so, how do I differentiate one USB stick from the other in MPad (iPad Mini)?
unincognito
    • bryston.com
Re: Using 2 USB Sticks with my BDP-2
« Reply #1 on: 29 May 2014, 01:14 am »
Hi
That should be fine, the BDP will just mount it as MUSIC1 rather then MUSIC
Cheers
Chris
