0 Members and 1 Guest are viewing this topic. Read 1319 times.
Free Tracks Format ComparisonHere is a zip file containing samples of 2 tracks in 4 different formats.A: 96/24 WAVB: 96/24 FLACC: 16/44 WAV (CD)D: 320kbps MP3All the different formats have the same source file 96/24 WAV (Studio Master).We used WAVELAB for the conversion.When you compare the files start with the lowest resolution: D (MP3 320 kbps) and move on up through example C and B ending with A.Be careful: If you start with A, and move down through B and C ending with D, your mind will remember the ''Blueprint'' of the higher resolution file, making it difficult to hear the difference even when finally listening to the MP3 file. Don't be frustrated if you can't hear a difference at first. Hearing is as individual as taste but hearing is also something which can be acquired, like the taste of good wine.1. BATIK - The DefeatA: 96/24 WAVB: 96/24 FLACC: 16/44 WAV (CD)D: 320kbps MP32. Carmen Gomes Inc - A Thousand Shades of BlueA: 96/24 WAVB: 96/24 FLACC: 16/44 WAV (CD)D: 320kbps MP3
