Do optical inputs die?
0 Members and 1 Guest are viewing this topic. Read 1864 times.
Carlman
« on: 23 Aug 2004, 07:29 pm »
I have a Panasonic XR-25 that no longer makes sound on 1 of the optical digital inputs.  If I swap inputs in the menu to 'optical 1' there is sound.  If I connect the same cable to optical input 2, and then change the menu to match it, there is no sound.
Has anyone ever heard of this happening?  I've never had a digital input go bad.  The DVD player (matching Panasonic) only has an optical output, which is glowing a nice red but there is no coax output to test.
Any ideas are appreciated.
-C
Carlman
« Reply #1 on: 24 Aug 2004, 02:08 am »
I guess I should mention that the cd player's optical output works because I get sound when connected to optical input 1 only.
Red Dragon Audio
    • http://www.reddragonaudio.com
« Reply #2 on: 24 Aug 2004, 03:27 am »
the real questions is; do optical inputs live?
jqp
« Reply #3 on: 24 Aug 2004, 04:41 pm »
DSP boards certainly die (mine did on my Outlaw 950, which I just a moment ago received after having the DSP board replaced).
I would think that only one port could go bad, although I didn't test all of mine - I stoppped at 2 of 4 optical ports, and I didn't try the coax.  I had an actual message on the display that said "s/pdif unlock".
shokunin
« Reply #4 on: 24 Aug 2004, 04:58 pm »
Yup, I have the same thing happen on my cheapie Pioneer receiver, all but one of the toslinks works.  just died all of a sudden.   Of course, mostly video gear come with optical outputs so the toslink inputs are at a premium.
Carlman
« Reply #5 on: 24 Aug 2004, 05:30 pm »
I can see how only 1 would die if the actual port had a problem.  If all the digital inputs died, that'd be easier to figure out... like a bad power supply for the digital board or something...
I kept thinking I might have a spec of dust causing the problem.. but, nothing gets moved, it's all been connected the same way for several months and hasn't been moved... Plus, it's all connected to a fairly large Tripplite battery backup/voltage regulator... and it stays fairly clean.  There's no dust on anything.
It's just frustrating that it was instantly isolate-able to the port itself.  I think I have a coax output from the cable box.  If so, I might be in business again.  I hope so.  The last thing I need is another revamped project.  :lol:
bubba966
« Reply #6 on: 24 Aug 2004, 05:59 pm »
Did that optical input ever work?
Carlman
« Reply #7 on: 24 Aug 2004, 07:19 pm »
Oh yeah.. this was a set-it and forget-it situation.. The cable box and DVD player have been plugged into opt 1 and opt 2 for months.  The cable box was in opt 1 and the dvd in opt 2.  I hadn't used the DVD player in a week and I went to play a movie... nothing.  The display says '6 ch DVD' but there are no red lights indicating what type of surround it selected... as if there is no digital input connected or used.
I plugged in the RCA L&R analog outs to the L&R analog inputs of 6-channel input area for the DVD player and got L&R sound only... no center.. and no way to take it off the '6-channel' input type.  I did have a hard time getting some dvd's to read, though.  Maybe there's more to it... but I don't know what the deal is...
-C
jqp
« Reply #8 on: 24 Aug 2004, 10:05 pm »
It could be something like a cold solder joint.
I don't think that these optical connections are very high tech - they are just rapid flashes of LEDs and I think there is a lot of tolerance on the connection.
I don't thnk you can send digital audio via analog outs, so your dsp would have to create a center channel from stereo. To get that multichannel I think you need digital optical or digital coax. Or am I missing something?
