bp26 problems ...... source selector switch
0 Members and 1 Guest are viewing this topic. Read 921 times.
Robert D
« on: 19 May 2014, 11:29 am »
Help Needed bp26 problems ...... source selector switch.
When I go to Tuner ...
There is not a good contact beaning made... Lots of distortion I have to play with the knob moving back and forth till the sound is clean & clear ....Other types of sounds as well coming from the switch in the Tuner position..
  All other positions of the selector switch seem to be fine.
Does the selector switch have to be changed.... ?
Thoughts Please !
Let me know
Regards Robert
  • The Demo is Everything!
    • http://www.bryston.com
Re: bp26 problems ...... source selector switch
« Reply #1 on: 19 May 2014, 12:12 pm »
Thoughts Please !
Let me know
Regards Robert
Usually if you just rapidly rotate the selector switch quickly a few times it will clean the contacts.
Make sure the amp is off when you do the rapid rotation.
Also try the tuner in a different input to make sure it is not the tuner.
james
Robert D
« Reply #2 on: 19 May 2014, 01:36 pm »
Thank you James
I'll try that
Regards Robert
drummermitchell
« Reply #3 on: 19 May 2014, 01:43 pm »
Robert,perhaps some DeoxIT pro gold:
