New Behringer Models
0 Members and 1 Guest are viewing this topic. Read 962 times.
klh
« on: 23 Aug 2004, 04:13 am »
Behringer has a few new models that have a 31 band EQ with the feedback destroyer that can even act as a DAC. Do any of you have experience with any of the newer models and whether they would be good as either an active crossover for a two way speaker or as a crossover for passive subs powered by say a Crown amp?
The ULTRAGRAPH DIGITAL DEQ1024 seems the best but the ULTRAGRAPH PRO FBQ6200 might also be good.
Any opinions?
Krister
klh
« Reply #1 on: 25 Aug 2004, 03:52 am »
Anyone? Any comments?
PEB
    • http://www.BambergAudio.com
« Reply #2 on: 31 Aug 2004, 01:25 pm »
Hi Krister,
Just saw your message.
I use the DCX2496 with great success on my upper echelon speaker systems.
The DCX is your best choice for active crossover duty, WITH EQ.  You will eventually learn that 31 bands is not necessary for proper EQ.  In my reference system I use just 3 EQ's: trap a single room mode in the bass, use another for overall bass level, and a PEQ in the mid treble.
Have a look at my site for more inside info on DCX real-world applications.
