12FV7 RCA USA Tube drop in replacements for 12AU7
0 Members and 1 Guest are viewing this topic. Read 5266 times.
mgsboedmisodpc2
Are 12FV7 RCA USA Tube drop in replacements for 12AU7 for prima luna prologue model 5 amp.  I ask because there specs are different
12FV7
Base Noval, B9A
Filament Vf 12.6 Volts / If 0.45 Ampere / Indirect /
Description Durch Heizfaden-Mittenanschluss auch Betrieb mit 6.3 V und 0.9 A möglich.
12AU7
Base Noval, B9A (Codex=No 15)
Filament Vf 6.3 Volts / If 0.3 Ampere / Indirect / Parallel / series AC/DC /
Description Centre-tapped heater permits operation at 12.6V 0.15A.
JakeJ
Re: 12FV7 RCA USA Tube drop in replacements for 12AU7
« Reply #1 on: 18 May 2014, 04:42 pm »
THe 12FV7 is not a direct replacement for the 12AU7.  You would need to make changes to components around the tube to correctly operate it.
Here is a great resource for tube data and substitutions.
http://tdsl.duncanamps.com/
mgsboedmisodpc2
« Reply #2 on: 18 May 2014, 08:14 pm »
good to know but some ebay listings are just confusing "12FV7 RCA USA Tube 12AU7 12AT7 Instant plug-in upgrade Long Box Plate NOS"
http://www.ebay.com/itm/12FV7-RCA-USA-Tube-12AU7-12AT7-Instant-plug-in-upgrade-Long-Box-Plate-NOS-/261479610593?pt=Vintage_Electronics_R2&hash=item3ce16638e1
avahifi
    • http://www.avahifi.com
« Reply #3 on: 18 May 2014, 08:54 pm »
Well, since the 12FV7 pulls three times as much heater current as a 12AU7 (.45 amp compared to .15 amp) I certainly would not consider it a drop in replacement unless you have a very robust heater current supply at least.
Oh well!
Frank Van Alstine
« Reply #4 on: 18 May 2014, 09:03 pm »
Thanks for explain. Both are similar, the gain is around u20.
FireGuy
« Reply #5 on: 18 May 2014, 09:35 pm »
6V6 and Yankees... = happiness
