0 Members and 1 Guest are viewing this topic. Read 5658 times.
No i use digital button and both cables are plug (coax and AES/EBU) and i use bal 2 inputthe cd input with coaxial is set for SPDIF 1 the AES/EBU cable is on bal 2 inputand the if i unplug the coaxial cable, no sound on the bal 2 inputSure there is a setting forMartin
yes i press the digital button first and Yes the first line display read AES2 DIGwhen i only plug the AES/EBU cable i have no audioi add a coaxial cable and the audio is running and line 1 display AES2 DIG too i tried 2 different AES/EBU cable and no sound for bothnow i think that it is a sp3 or bcd-1 issuehow will i find itMartin
quebec citydealer is Audiolight
I have the same problem - the sp3 doesn't recognise there's an AES signal. It worked fine before (bal1 to a cd transport and bal2 to a bdp) but since upgrading the sp3 firmware to 2014.07 I get no sound at all from the sp3 from either source. I think this is because it's not recognising there's an AES signal because the display says "bal1 digital no". Switching between all other sources (opt, coax and hdmi) and it works fine...Any ideas for how to fix this would be appreciated !Ian
