Audio/Video Gear and Systems
The Vinyl Circle
woodsyi
Brinkmann
Brinkmann
0 Members and 1 Guest are viewing this topic. Read 1062 times.
neobop
BIRD LIVES
Brinkmann
17 May 2014, 01:40 pm »
I mentioned the Brinkmann Bardo in another thread. This is the latest direct drive from Brinkmann and their least expensive table - approx. $8K w/o arm.
http://www.brinkmann-usa.com/main.php?prod=bardo&lang=en
The Oasis is also direct drive and looks like a Bardo with a conventional plinth. The other 2 tables are more expensive belt drivers.
One thing I thought was crazy was a tube power supply for a table. Maybe it's not so crazy.
http://www.brinkmann-usa.com/main.php?prod=roent&lang=en
http://www.stereophile.com/content/brinkmann-audio-bardo-turntable
neo
neobop
BIRD LIVES
Re: Brinkmann
21 May 2014, 01:50 pm »
Bardo has a 22 lb platter and specially designed coreless motor. While Fremer played with it (substitute arm/cart) just long enough to find something negative to say, that's not the case with other reviewers. Here's an example:
http://www.theaudiobeat.com/equipment/brinkmann_bardo.htm
To elucidate on that deep bass aspect, I think this might be a more revealing opinion of actual differences:
http://forum.audiogon.com/cgi-bin/fr.pl?eanlg&1350410941&openusid&zz213cobra&4&5
neo
The Vinyl Circle
woodsyi
Brinkmann
