bdp1 playlists
0 Members and 1 Guest are viewing this topic. Read 1359 times.
Robin1
bdp1 playlists
« on: 16 May 2014, 01:16 am »
I recently updated my Ipad......then updated mpad
now when I open my playlists they all appear empty.....nothing opens in the player
everything else seems to be fine
tried updating cache....reboot ipad
 Would hate to start over on my playlists
anyone have any ideas.....or is this just normal when updating
thanks
Robin
unincognito
    • bryston.com
Re: bdp1 playlists
« Reply #1 on: 29 May 2014, 01:20 am »
thanks
Robin
Which version of the firmware is the BDP running?
Cheers
Chris
Robin1
Re: bdp1 playlists
« Reply #2 on: 30 May 2014, 01:51 am »
51.40    2012-05-10
unincognito
    • bryston.com
Re: bdp1 playlists
« Reply #3 on: 3 Jun 2014, 02:05 am »
51.40    2012-05-10
Updating the firmware will install a new feature called "service mode", turning this on allows us to diagnose software issues remotely.
http://www.youtube.com/watch?v=h3gqzF74Z74
Cheers
Chris
Robin1
Re: bdp1 playlists
« Reply #4 on: 3 Jun 2014, 09:19 pm »
got it....did the updates
I had to update cache 10-15 times before I see all my music....I think everything is okay except I seemed to have lost my playlists
I can start over on that next rainy day
thanks for the help Chris
Robin
unincognito
    • bryston.com
Re: bdp1 playlists
« Reply #5 on: 5 Jun 2014, 05:24 pm »
Robin
Hi Robin,
If you enable service mode, email me the service ID I can check to see if they are still in the filesystem or if they are actually gone.
https://www.youtube.com/watch?v=I0nfBG5xDrA
Chris
BozemanEric
Re: bdp1 playlists
« Reply #6 on: 8 Jun 2014, 11:31 pm »
Were you using MPad?  I had a very similar problem. My iPad just stopped recognizing all of the files. I would open MPad and it would be blank. I tried everything I could think of, looked through countless forums, reset the iPad, tried to rebuild playlists, reinstall MPaD...  Finally I gave up and just installed MPaD on my iPhone.  I used it on the iPhone and it worked flawlessly, but I could not get it to recognize any files on the iPad. I would sporadically check the iPad and about a month later all the files just magically appeared again. It has worked flawlessly on my iPad ever since then.  I have no idea where they went, or how they came back.
Robin1
Re: bdp1 playlists
« Reply #7 on: 9 Jun 2014, 04:01 pm »
Hi guys
yes I am using mpad...sounds like the same problems, after I updated When searching for by artist only half the alphabet was there and my playlists are empty
and I'm using the man cave option....not connected
I'm in the middle of moving so maybe when I get moved it will all come back
thanks for the feedback
