3 ncore can output 1200W on 4 ohm???
0 Members and 1 Guest are viewing this topic. Read 3185 times.
this_is_vv
« on: 13 May 2014, 06:47 am »
so wanted to know...is it possible to join 3 ncore and get 1200W on 4 ohm...i have pair of 3 ncore each pics here..
http://www.audiocircle.com/index.php?topic=120365.0
can they be joined to give 1200W output power....or two either...
thought i ask....need for some maggie 1.7...heard more the power more they sing....
V
Julf
  • Grumpy second cousin of Mark V Shaney
Re: 3 ncore can output 1200W on 4 ohm???
« Reply #1 on: 13 May 2014, 09:24 am »
Seems you are getting much more responses over at diyaudio, so I am not going to repeat my answer here.
jtwrace
    • TIPP YouTube Channel
« Reply #2 on: 13 May 2014, 11:34 am »
V
Yes, but you probably don't need to do so.  However, if you feel as though you need or want more power you should think about some NC1200 based amps then.  Maggies can only go so loud before distortion anyway.
hifial
  • Ambassador, Sound Galleries & Taiko Audio
    • Sound Test
« Reply #3 on: 13 May 2014, 02:36 pm »
I agree with Jason.
FYI;
 I fellow audiophile who owns Maggies was using a pair of LARGE ARC monos to power his Maggies. He tired a pair of NC1200 monos, said his Maggies never sounded better and has never looked back.
Try them, but only if you are prepared to buy them.
Julf
« Reply #4 on: 14 May 2014, 06:37 am »
I assume he didn't try nc400's, so we don't know if he would have liked a nc400 just as much?
greenkiwi
« Reply #5 on: 30 May 2014, 05:19 am »
I feel like I've seen comments about bridging 2 nc400s.  That being said, I have the nc400s and Magnepan 3.6s and I don't think that I really need any more power than they provide.  (maybe I would if I heard the nc1200s or something... but best not to listen when one doesn't have $10k burning a hole in ones pocket.)
